sedgey Posted December 28, 2013 Share Posted December 28, 2013 Has anyone managed to set up a dual amp/stereo patch using both the l2t and dt25 over line 6 link?Maybe more of a feature request than a current possibility, but just thought I'd ask the veterans anyway, thanks in advance Quote Link to comment Share on other sites More sharing options...
NBell Posted January 2, 2014 Share Posted January 2, 2014 Via POD HD? Quote Link to comment Share on other sites More sharing options...
wicker_man Posted January 2, 2014 Share Posted January 2, 2014 I'm assuming sedgey means via L6 link from the POD HD. I would think the issue would be that the output mode of the POD will default to STACK PWR AMP when connected to the DT25, which would make the output from the L2t sound poor. Line 6 advise to connect the DT25 first in the L6 link chain - I'm not sure if connecting the L2t first would force STUDIO/DIRECT mode. To me, this would make more sense as you could assign the DT25 to one of the amp models and select "no cab" to inhibit the cab and mic simulation. There isn't really much guidance from Line 6 about how to use these two amps together in a guitar rig, although it is inferred in the POD HD Pro Advanced Guide page 2-17: "Note: It is necessary to always place the StageSource speaker(s) last in the L6 LINK signal chain (e.g. - POD HD Pro > DT50 > StageSource L3). For more about using the L6 LINK connection, DT Series amps & StageSource speakers, please see the additional documentation available at http://line6.com/support/manuals/." And for the life of me, I can't find anything more on this topic at the URL quoted in the manual. The L6 link connectivity guide only covers DT amps. Quote Link to comment Share on other sites More sharing options...
sedgey Posted January 3, 2014 Author Share Posted January 3, 2014 Yes I mean do mean with the Pod HD500, my logic so far goes something like this: podhd output mode combo front l2t speaker mode guitar left channel to DT25 with pre model right channel to L2t with full model Balance Volume on both the L2t and DT25, EQ to taste, haven't been able to get to the studio to try this yet. 1 Quote Link to comment Share on other sites More sharing options...
wicker_man Posted January 3, 2014 Share Posted January 3, 2014 Well, I've just taken delivery of an L3t today, so I've given this a go... You've got it pretty much spot on. The key is having the L2/L3 speaker mode set to electric guitar and not reference PA. That accounts for the POD output mode being forced to STACK PWR AMP when connected to the DT via L6 link. I put pan pedal after the mixer to pan between the DT and L3 and although they sound slightly different (which might be expected as I was using my own cab with the DT), both sounded really good. I just used a JCM 800 model with everything set to 12 o'clock on the pre- and full models. I can see myself spending hours setting up some nice dual and stereo patches now :D Quote Link to comment Share on other sites More sharing options...
