m1tp2king Posted June 7, 2019 Share Posted June 7, 2019 hi. I read in the manual that if you don't have enough DSP to process your effects that you want to use in path 1 , you can then transfer some effects to path 2. the manual is a little confusing. what page of the manual Is relevant. Is there a resource on the WEB that can help me to understand better. I am new to this, please be patient with me. many thanks. Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 7, 2019 Share Posted June 7, 2019 To do this you need to select the Output block of Path 1 and set the output value/route to 'Path 2A'. This routes the signal from the top Path into the bottom Path, enabling the full DSP resources of both paths to the input signal to Path 1. Quote Link to comment Share on other sites More sharing options...
spikey Posted June 7, 2019 Share Posted June 7, 2019 Silver is exactly correct as I do this all the time. Look on the editor and click on the end of the chain/path where it says "Multi". Select "Path 2A" right underneath it. Quote Link to comment Share on other sites More sharing options...
