J-Abel_Gilmour Posted June 17, 2019 Share Posted June 17, 2019 Hi, Line 6!!!! I want to buy the HX STOMPBOX. But I have a question. Is it possible to use two types of simultaneous delay? for example, that a ping-pong stereo delay with a mono tape delay (at the same tempo, logically) is played at the same time. Is that possible with the line 6 HX STOMPBOX? Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 17, 2019 Share Posted June 17, 2019 Yep... You can have all 6 blocks be delays if you want. You can have multiple instances of any block (mostly). There are a few blocks for which there are set limits (amps, cabs, IRs), but for effects, you're just limited by the available DSP. Quote Link to comment Share on other sites More sharing options...
Kevin-M Posted June 18, 2019 Share Posted June 18, 2019 Absolutely. 6-2 delays leaves 4 more blocks to use! Quote Link to comment Share on other sites More sharing options...
