pwilly Posted June 21, 2019 Share Posted June 21, 2019 I mistakenly assigned a block to a switch and can't figure out how to remove it so I can assign a different block to it. Quote Link to comment Share on other sites More sharing options...
Verne-Bunsen Posted June 21, 2019 Share Posted June 21, 2019 I’m not at my Helix presently so bear with me, but if you select the block in question and go into the settings menu, you’ll find an option called “Bypass Assign” or something similar. Go in there and change the assignment to “none”. Quote Link to comment Share on other sites More sharing options...
teo-torriate Posted June 21, 2019 Share Posted June 21, 2019 To assign a different block to a used switch select the new block and touch the switch you want to change. The dialog "Assign footswitch..." wll be shown. Then choose "Replace" on the "Merge"-knob and save ("OK"). That's all. :-) Quote Link to comment Share on other sites More sharing options...
pwilly Posted June 22, 2019 Author Share Posted June 22, 2019 Ahhh... That's the ticket! I was working on a Guitar + Vocals template that I was hoping to remove EQ from a switch since it will always be active and leave an extra unused switch for future needs but this is a simple enough fix if a different block is needed for a specific song. Many thanks! Quote Link to comment Share on other sites More sharing options...
