Profett Posted January 2, 2014 Share Posted January 2, 2014 when connecting m20d via 6link to l3t does the l3t mixer affect the sound that comes from m20d? Profett Quote Link to comment Share on other sites More sharing options...
dboomer Posted January 2, 2014 Share Posted January 2, 2014 The mixer doesn't override the built-in EQ or other processing in the speakers. Beyond that it could if you make changes in the output bus of the mixer. You can also adjust the built-in 1/3rd graphic in the speakers from the mixer. Quote Link to comment Share on other sites More sharing options...
Digital-sound Posted January 6, 2014 Share Posted January 6, 2014 The mixer doesn't override the built-in EQ or other processing in the speakers. Beyond that it could if you make changes in the output bus of the mixer. You can also adjust the built-in 1/3rd graphic in the speakers from the mixer. Too many "mixer" words. I understand the short answer is no. Plugged in to the L6 link, the mixer on the speaker will do nothing correct? Unless maybe it affects instruments plugged into the mixer side of the speaker? I only use mine as front end, and sometimes as a monitor on another system, so I have not experimented. Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 6, 2014 Share Posted January 6, 2014 My understanding is that the mixer on the L3t only affects the channel inputs on the L3t - the inputs built in to the bottom of the mixer panel itself. The L3t mixer does not affect the sound coming from the M20d mixer over L6 Link, nor the rear panel inputs on the L3t. Quote Link to comment Share on other sites More sharing options...
dboomer Posted January 6, 2014 Share Posted January 6, 2014 Too many "mixer" words. I understand the short answer is no. Plugged in to the L6 link, the mixer on the speaker will do nothing correct? You are correct ... NO. The mixer just "conditions" the signal that is sent out. Quote Link to comment Share on other sites More sharing options...
