homegrownbuddy Posted July 12, 2019 Share Posted July 12, 2019 This may be a silly question but how do I make changes to the actual signal chain(not parameters) between snapshots. For example in snapshot 1 the amp is third in the chain, for snapshot 2 Amp is 4th in the chain.Or even snapshot one has one path but snap two has 1 and 2A etc. Whenever I try to do this and even add something between the two and switch back they are in snap1 like it's applied to all snapshots. Am I going about this wrong? I got the parameter thing down, I can change those per snapshot easy by right clicking and setting snapshot so it turns white. But how do I go about moving whole blocks around so they only move in one snapshot? Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted July 12, 2019 Share Posted July 12, 2019 4 minutes ago, homegrownbuddy said: This may be a silly question but how do I make changes to the actual signal chain(not parameters) between snapshots. For example in snapshot 1 the amp is third in the chain, for snapshot 2 Amp is 4th in the chain.Or even snapshot one has one path but snap two has 1 and 2A etc. Whenever I try to do this and even add something between the two and switch back they are in snap1 like it's applied to all snapshots. Am I going about this wrong? I got the parameter thing down, I can change those per snapshot easy by right clicking and setting snapshot so it turns white. But how do I go about moving whole blocks around so they only move in one snapshot? Snapshots only allow you to change perimeters and statuses on existing signal chains. You can't actually change the blocks (i.e. digital architecture) of those signal chains. To do that you need a new preset. Quote Link to comment Share on other sites More sharing options...
homegrownbuddy Posted July 12, 2019 Author Share Posted July 12, 2019 thank you Quote Link to comment Share on other sites More sharing options...
PiFromBRC Posted July 13, 2019 Share Posted July 13, 2019 Interesting request though. Quote Link to comment Share on other sites More sharing options...
