Merlin5150 Posted July 25, 2019 Share Posted July 25, 2019 I’m considering the MKII and was wondering how IR’s in my HXFX work with is amp? Thanks Jeff Quote Link to comment Share on other sites More sharing options...
gtrman100 Posted July 25, 2019 Share Posted July 25, 2019 If you are asking whether or not you can load external IR's into a Spider amp, the answer is no. The amp and cab models are imbedded into the amps software and can only be changed through a software update from Line 6. That said, there are a ton of different cab models in the Spider software that can give you a wide range of tones. Quote Link to comment Share on other sites More sharing options...
Merlin5150 Posted July 26, 2019 Author Share Posted July 26, 2019 Ok and thanks for commenting . I’d just use the IR’s in the HX then. I’ll have to try one out. I have the SpiderV 20 and it sounds really good. Quote Link to comment Share on other sites More sharing options...
bobcoss Posted July 27, 2019 Share Posted July 27, 2019 Hi, I have HX Effects and a V 240hc. There is no send/return and all of the modeling associated with amps in the Spider V contain their equivalent of the IRs for those different cabinet options. I don't think using the IRs in the HXE are going to do much for you. The only way to use the IRs in HXE is in front of the amp, and the najority of IRs are designed to emulate only a cabinet. The IR blocks in HXE are great for acoustic guitar IRs. If you get something figured out that you like the sound of, please share the info. 1 Quote Link to comment Share on other sites More sharing options...
