ezut Posted August 6, 2019 Share Posted August 6, 2019 What is the difference between "master volume" and "chanel volume" in amplifier parameters? Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 6, 2019 Share Posted August 6, 2019 19 minutes ago, ezut said: What is the difference between "master volume" and "chanel volume" in amplifier parameters? Hi, Essentially the channel volume doesn’t effect the overall sound of your amp model whereas master volume is exactly that, a master volume. Example: if you have a nice clean amp set up and another high gain preset in the next slot, then obviously the high gain model will be cranked up so that when you swap to the clean amp you perceive a difference in loudness. You would use the channel volume to adjust either or both to even up the output, without changing the overall sound of each model. Basically channel volume has no effect on your overall tone and is used for level matching. Hope that helps / makes sense. 1 Quote Link to comment Share on other sites More sharing options...
Verne-Bunsen Posted August 6, 2019 Share Posted August 6, 2019 23 minutes ago, datacommando said: Basically channel volume has no effect on your overall tone and is used for level matching. This. "Master Volume" controls how hard you are driving the output stage of the amplifier in the same way that "Drive" controls how hard you drive the preamp, so it is a big tone lever. 1 Quote Link to comment Share on other sites More sharing options...
ezut Posted August 6, 2019 Author Share Posted August 6, 2019 Thanks for your quick reply. Quote Link to comment Share on other sites More sharing options...
