AndyDSA
PowerCab Plus L6 Link input (or cable) has blown
Hi all
Have newly purchased a PowerCab Plus here in Australia and connected it to my Helix LT with a 3m  110ohm AES/EBU cable as per this link:
https://www.swamp.net.au/swamp-aes-ebu-cable-110ohm-dual-shielded-digital-audio-cable
I had the connection running OK for just over day with global sample settings on the Helix at 44.1
Was playing a single amp model/looper only from the Helix on full volume but the PowerCab was only at 30%. All of a sudden I get a 'bang and a flash' from the PowerCab L6 input port and I lose sound.
I tried the 1/4 inch connection and, although noisy, the PowerCab still appeared to work OK
I have reviewed other threads on signal drop out but this was total loss with a big noise.
The cable appears to meet requirements and I can't see any other settings that I needed to configure for the connection.
Before I contact the cable supplier and Line 6 here in Australia,  has anybody had this issue or got any suggestions to troubleshoot? I am not sure if it is Cable or Powercab itself
When you say you got a "bang and flash", do you mean you saw an actual electrical arc? Was there smoke? I mean, it's certainly possible the cable failed, but if there was arcing involved, that sounds like something more.
