Heavyville Posted August 20, 2019 Share Posted August 20, 2019 maybe there is already something addressing this already. purely a lazy question right now. anyone notice saving snapshots via HX edit does weird things to all the other snapshots. For instance saving a snapshot with Delay and reverb turned on the day and rev for all snapshots. Could;t get around it... However double saving every snapshot from the actual unit seemed to work. I can live with it, but i'm sure we can figure it out team !!!!! GO! i'm hoping its a DFU error, those are easy to fix. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted August 20, 2019 Share Posted August 20, 2019 1 hour ago, rucmas said: maybe there is already something addressing this already. purely a lazy question right now. anyone notice saving snapshots via HX edit does weird things to all the other snapshots. For instance saving a snapshot with Delay and reverb turned on the day and rev for all snapshots. Could;t get around it... However double saving every snapshot from the actual unit seemed to work. I can live with it, but i'm sure we can figure it out team !!!!! GO! i'm hoping its a DFU error, those are easy to fix. That's just how they work... in any new patch, when you set up your first snapshot, the remaining 7 snapshots will be identical by default, until you go into each one individually and make one or more changes. "If you select a snapshot that hasn’t yet been altered, it appears the same as the snapshot you came from. As soon as you alter a new snapshot (say, by enabling or bypassing an amp or effect block), the snapshot becomes "active" and remembers any changes." https://helixhelp.com/manuals/helix/snapshots.html#snapshots-block-bypass Quote Link to comment Share on other sites More sharing options...
Heavyville Posted August 20, 2019 Author Share Posted August 20, 2019 13 hours ago, cruisinon2 said: That's just how they work... in any new patch, when you set up your first snapshot, the remaining 7 snapshots will be identical by default, until you go into each one individually and make one or more changes. "If you select a snapshot that hasn’t yet been altered, it appears the same as the snapshot you came from. As soon as you alter a new snapshot (say, by enabling or bypassing an amp or effect block), the snapshot becomes "active" and remembers any changes." https://helixhelp.com/manuals/helix/snapshots.html#snapshots-block-bypass I get that part, that isn't new. I discovered while buiding a new patch with snapshots that after everything was saved and I got my snapshots in order. I was fine tuning them and turned on/off a few blocks. While hitting the save button on HX edit i noticed that it saved all the blocks the same for all snapshots. So if i had a boost on for a lead, all the snapshots now had the boost engaged which is not a normal behaviour. using the save button on the physical unit solved the issue and the snapshots saved correctly. Quote Link to comment Share on other sites More sharing options...
