rudomat Posted September 12, 2019 Share Posted September 12, 2019 hi, question concerning the hx stomp: can i run the unit in 4CM and have the preamp-fx turned off in true bypass (fully analog!), while the post-preamp-fx are still active...? is this possible? thanks Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 12, 2019 Share Posted September 12, 2019 If I'm reading the manual correctly, that would send the Input (guitar) signal directly to the Output which, in 4cm, is connected to your amp's FX Loop Return. Same as running a jumper wire from the Input to the Output. ALL blocks, including the Loop, bypassed. Quote Link to comment Share on other sites More sharing options...
