dt50 bias probe points
hichembell
Before taking my line6 DT50 To a pro tech for biasing, I would like to collect some information first.
checking on google and youtube, I have found a step by step  guide to retube and bias a dt25 w combo:
on another topic hee on line6 forum, it is explained that in order to bias a DT50 one needs to use a dual bias tester  :
"plug the bias tester probes into the power tube receptacles of the amp, then plug the tubes into the bias tester probes which look just like the bottom of a regular tube. Basically, the power tubes are plugged into the bias probe which is , in turn, plugged into the power tube receptacle (they are stacked on top of each other)"
my question is: Does the DT 50 owns the same 3 holes for the test probe points and the hole for the bias adjustment like a DT25  or is it different in design, in this case, it is a must to use a dual bias tester to get it biased?
In other words, does the DT50 combo has such probes and holes that enable to bias the amp without using a dual bias tester :
I would like to inform you that I live In Algeria and there is no line6 shop or a line6  authorized repair, otherwise, I would directly take to such a repair center. My friend is a professional electronic.  engineer. He already repaired my DT50 and already changed its power transformer in the past. So, i would like to collect for him all the info, describe the procedure to him so that he will do it for me
thank you in advance.
  • 1 year later...
Hi there,
Have you received any clear answer to your question?
I would like to change the valves of my DT50 HD.......DT50HD, not the combo, not the DT25......and i can't find where the probe ports are nor which one is V1 which one is V2 etc...
Can you help?
Tahnks a lot in advance
Philtno
