Line & Instrument Level
guitarboy_02451
I'm Sure this has been asked before. Just got my HX Stomp, great rig! I've incorporated it into my existing pedal board via 4 CM putting my pedals in the FX Loop.
My output goes to either one of my Dr. Z amps. Right now I have the output going to my Dr. Z Carmen Ghia (which doesn't have an FX loop).
I noticed the audio level dropped, I swapped cables and plugged guitar directly into the amp, nice and loud and bright, put everything back through the Stomp and signal dropped.
Went in and changed the output from "Inst" to "Line", then I had unity (same signal from Stomp as guitar going direct to amp).  But I know this can't be right...  Line level is for low level signals like keyboards, etc.
9 hours ago, phil_m said:
Do you have the volume knob on the Stomp all the way up? With the input and output set to instrument level, that should give you unity gain through the Stomp.
thanks Phil, yes had vol about 2pm. Changed to inst, dimed the vol and I have unity. saw a Richie Catililano video and he had the same settings.
Thanks for your reply!
