USERLINE62K19 Posted October 17, 2019 Share Posted October 17, 2019 Hi, Can anyone suggest me which combination of output option should i select while performing live onstage ? Thanks . Quote Link to comment Share on other sites More sharing options...
hurghanico Posted October 17, 2019 Share Posted October 17, 2019 As suggested in the downloadable advanced guide select the Studio/Direct output mode if you go direct to the FOH and use a flat response monitor/amp, or one of the other output modes depending on which guitar amp type you are connecting the device to and how. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
joel_brown Posted October 17, 2019 Share Posted October 17, 2019 What do you plan to connect the PODHD to ? Otherwise your question is like asking "Can anyone suggest what guitar I should play live onstage ?". Quote Link to comment Share on other sites More sharing options...
USERLINE62K19 Posted October 17, 2019 Author Share Posted October 17, 2019 Hello thank you for your quick response, i m planning it to connect directly to the Mixer Board @ joel_brown. Also please suggest which will be the best output slot the Unbalanced one or the XLR ones. Thank you Quote Link to comment Share on other sites More sharing options...
USERLINE62K19 Posted October 17, 2019 Author Share Posted October 17, 2019 Thank you for your imidiate response i will surely try it while i m going through my amp. Actually i forgot to mention that i want to directly connect it to the mixer board without going through an amp @ hurghanico Quote Link to comment Share on other sites More sharing options...
hurghanico Posted October 17, 2019 Share Posted October 17, 2019 36 minutes ago, USERLINE62K19 said: i want to directly connect it to the mixer board without going through an amp @ hurghanico Select Studio/Direct output mode. 40 minutes ago, USERLINE62K19 said: suggest which will be the best output slot the Unbalanced one or the XLR ones. If your POD is very far from the FOH mixer and you need to use very very long cables to make the connection, and if the FOH mixer has a MIC level input channel available, use XLR.. otherwise use the standard 1/4" unbalanced jack output which can give a hotter LINE level signal if the 1/4" OUT switch near the pedal is set to LINE. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted October 17, 2019 Share Posted October 17, 2019 1 hour ago, hurghanico said: If your POD is very far from the FOH mixer and you need to use very very long cables or, they will run a snake, the same as they would for microphones that way there isn't a dozen individual wires being draped across the dance floor 1 Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted October 17, 2019 Share Posted October 17, 2019 just to repeat what everyone else has said - studio/direct XLR when possible (it isn't always available for small gigs) but never forget - do not design patches on a guitar amp, and then expect the same results from a pa you want to design your patches with the same setup as you will be using for performances 1 Quote Link to comment Share on other sites More sharing options...
USERLINE62K19 Posted October 21, 2019 Author Share Posted October 21, 2019 Thanks a lot @pianoguyy @hurghanico your suggestions worked too good. Got a mind blowing output throughout the gig. Both of u made my day.. :-) tc Quote Link to comment Share on other sites More sharing options...
