danplants24 Posted October 19, 2019 Share Posted October 19, 2019 I just recently purchased a Helix LT. Im running it into my MacBook pro recording with Logic Pro X 10.4.6 Im running the latest HELIX firmware and helix edit. The issue is when I’m trying to record into logic, there is a high pitch feedback coming from the guitar track that I recorded with the helix. The noise is not there when I’m not recording. I have looked everywhere online and no one has a solid answer. The issue isn’t there when I unplug the helix usb from my computer. Its only a problem when I am recording while I have the helix USB plugged in. Im using the XLR outputs to record. I keep the Helix USB connected to the macbook so I can edit the helix with the helix editor and pick different guitars out in workbench for the Varix. Having to unplug the helix USB from my computer is a huge inconvenience. Anyone having the same issue? I I can provide a video of the issue if you would like. Thank you. P.S. I am using a line 6 variax standard to record with. Quote Link to comment Share on other sites More sharing options...
Jojodayolo Posted October 24, 2019 Share Posted October 24, 2019 I have kind of the same problem. I have always a high pitched noise when the usb is plugged in but only on the 1/4 inch and xlr outs( dont know if its on the headphone out). But if I record something over the build in interface I have no noise. I use a macbook pro with Logic X. Tomorrow I can check if there is the same with a Windows PC and Cubase LE 9.5 Quote Link to comment Share on other sites More sharing options...
reginaldStjohn Posted October 24, 2019 Share Posted October 24, 2019 Is your computer and audio gear all plugged into the same wall outlet or circuit? This could be a ground loop. I had the same problem and fixed it by getting things all on the same circuit. However, it really depends on how the USB power is designed inside your machine. There are some devices out there that can try to isolate your USB or audio grounds. Have you tried the ground lift switch on the Helix? Quote Link to comment Share on other sites More sharing options...
Jojodayolo Posted October 24, 2019 Share Posted October 24, 2019 @reginaldStjohnThanks for the quick reply. So I tried the things you said, now my noise is gone on the XLR jack, but it's still on the 1/4 inch output. Right now I'm using an instrument cable that I think is suboptimal. Now with the working XLR it's fine for me, but it would be interesting to know if the balanced cable from Helix 1/4 inch to my interface would solve the problem. Another thing I discovered is that if I connected the Helix to the Mac via usb, but didn't select it as an input or output device in Logic X, the noise wouldn't be there. The moment I select the helix in Preferences>Audio>Devices (no matter if as output or input device) and click "Accept Changes", the noise appears. Quote Link to comment Share on other sites More sharing options...
Cactuspenii Posted August 19, 2022 Share Posted August 19, 2022 I FOUND A FIX! Helix floor Win 10 Go to sound settings and device properties for input Should be using line 6 DAI. Go to additional properties and then click the listen tab. Uncheck "listen to this device" box. No more feedback! 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 19, 2022 Share Posted August 19, 2022 On 8/19/2022 at 7:36 PM, Cactuspenii said: I FOUND A FIX! Helix floor Win 10 Go to sound settings and device properties for input Should be using line 6 DAI. Go to additional properties and then click the listen tab. Uncheck "listen to this device" box. No more feedback! Cool - good to know you fixed it. Hopefully the fix will help others. You do realise that you commented on a thread that has been happily sleeping for 3 years. ;-) Quote Link to comment Share on other sites More sharing options...
Cactuspenii Posted August 20, 2022 Share Posted August 20, 2022 And I unhappily had the same issue yesterday so I happily added some info for this as I did not find it on forums. Hope it works for others as well! 1 Quote Link to comment Share on other sites More sharing options...
