64 bit
Glowzinski85
  • 1 month later...
On 10/25/2019 at 5:46 PM, Glowzinski85 said:
I want to upgrade Mac OS.  It is 64 bit only.  I see that two Line 6 programs will not work.
Line 6 monkey
and
Line 6 license manager
How can I upgrade these so they will work?
I don't think should be an issue as when I looked up these 2 for download is just states on the right what versions of OS X the current version is supported. If you've tried it and it's not working then give us some more details to try to help you out.
Jd
Jd
You can say that, but I got an email from L6 saying.... I don't remember what it said.
But, to paraphrase, it said don't do it.
Interesting. So why would it state on the download page it's supported and I have both running fine on my MacBook with OS X.
Jd
I was able to get the Pod500x Edit, Line6 license Manager, and Workbench HD to work with macOS Catalina.
the post at the following link helped me to figure it out: Helpful link.
however, the Line6 Monkey software is not compatible with Catalina.  To make the others recognize my Pod HD500X I had to install the Line6 usb drivers and authorize  them in the security preference panel after reboot.  Once that was completed I had full access to the Pod500x edit and license manager.
