Starting problem
sotirisand
1. disconnect everything from the POD
2. connect the power cable will pressing the  down button
3.after it the screen will say "update flash".
4.connect the usb cable and run line 6 monkey program.
5.select "flash memory" and reinstall latest version.
6.after finishing just restart your pod.
If it doesn't solve the problem check also if the power supply is still giving the necessary current to the device.
_______________________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
help and useful tips
