munkeyboy7777 Posted December 7, 2019 Share Posted December 7, 2019 As the title says, this M5 has the Right (mono) channel which is overly loud and has a lot of bad gain. Almost as if some distortion effect is always on. Interestingly, if I plug inputs and outputs into both channels, then it quiets down and behave as I expect. I've tried a factory reset with no change. I'm handy with electronics, but before I dig out my multimeter and solding iron, I thought I'd ask. Is there some setting that is causing this (that sticks even with a factory reset)? Quote Link to comment Share on other sites More sharing options...
brunoenglr Posted February 26, 2020 Share Posted February 26, 2020 Hello man, im having the same issue here just bought a M5 and when im plugged on mono input, the sound gets a little weird and starts to add some distortion (some signal and volume is also lost) Did you had any sucess finding the problem? when i use on stereo everything is fine but then i cant use the tuner, and i really need the tuner. thanks Quote Link to comment Share on other sites More sharing options...
