So - my 300 died in the middle of playing it the other night. Tested power supply, with a battery, etc - nothing.  It stuttered a bit before finally going, so I'm concerned the circuit board went.
Need to get it back up and running asap.  Is there anywhere I can buy a 300 circuit board?
Before someone else chimes in, I found none on Full Compass. They have other 300 electric parts,
but not a main board.
Make certain the guitar is registered in your account, then log a support ticket.
It should be evaluated by a Line 6 technician or authorized service center to determine if it is the board,
or something else internally failing.
Where can I find the serial number on my Variax 300 to register it?
Back of the head-stock.
When you go into the registration window and click on the product,
the prefix will appear and you simply type in the rest of the number from what is on the head-stock.
I changed the neck.   Now, where is that confounded neck...?
<no answer needed>
