HX effects - permanently assigned effect !
kondradd23
Hello, I have unusual problem with my hx effects. One of delay blocks "simple delay" is permanently assigned. It means that I have it in all presets (but it's not visible in signal flow) and I can't turn it off. What i have done so far:
-restore factory presets and global settings
-reinstalled 2.82 firmware
-downgrade to previous firmware and than to 2.82
I still can't fix this problem. Did anyone have a similar problem? Please, help 1f641.png
I suspect this is a doubling effect of some sort coming from some other piece of equipment in your setup.
Try this to test using only the HX FX:
- connect your guitar directly to the HX FX Guitar input
- connect headphones to the L/Mono output of the HX FX
- to protect your ears set the Global Settings -> Ins/Outs -> Output Level to Instrument
- select an empty preset (New Preset)
- turn your guitar volume knob down to zero. Slowly increase it as you play single notes until you can clearly hear the notes through the headphones
Do you still hear a delay effect?
