Downloading audio into hx stomp?
kevinmiller124
Hi, this may be an ignorant question, but I'm wondering if it is possible to download pre-recorded audio into the hx stomp? For example, is it possible to somehow take an mp3/wav file, and download it onto the pedal (where the audio can be triggered with one of the footswitches and played back through whatever amp/speaker the pedal is hooked up to)?
Thanks,
Kevin
Thanks,
Kevin
No.
Not as you probably intend, but in a very limited way, yes, the Looper Block's memory could be used to hold a limited amount of material downloaded into the unit. However, as the material is not saved when the unit is powered down, the Looper would serve as a limited and short duration method.
