fgmarand Posted February 9, 2020 Share Posted February 9, 2020 Just had a problem yesterday on stage: plugging my Variax Bass to the Bass Pod XT Live with the Variax connector started causing variable issues: most of the time, the sound works, but the Pod is frozen: no way to change sounds, switch to tuning mode; and even the volume pedal does nothing. The pod display switches from its normal display (bank/number) to something with a dot in it and a lowercase letter sometimes, there is just no sound other times, there is a low-level sound, very weak. unplugging the Variax restores the Pod operation; replugging it makes the problem reappear Any suggestions ? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted February 10, 2020 Share Posted February 10, 2020 Both the bass and the POD need to be check by a Line 6 authorized service center. Voltage draw down somewhere cause other issues. Needs to be properly troubleshooted by a Line 6 authorized service center. That will not be user self repairable issue. Quote Link to comment Share on other sites More sharing options...
fgmarand Posted February 10, 2020 Author Share Posted February 10, 2020 Thanks for your answer. If I understand how the site works, it seems I should contact sav@melison.fr , that site being the only one listed around Paris. Is that correct ? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted February 10, 2020 Share Posted February 10, 2020 Yes, but call them first, check to be certain they can do both electronics and guitars. Could be something electronic in the bass guitar that is pulling down the POD, or the other way around. Quote Link to comment Share on other sites More sharing options...
fgmarand Posted February 18, 2020 Author Share Posted February 18, 2020 Finally got an answer from melison: they say Line6 no longer provides spare parts for the Variax 700 so they cannot do it. Any suggestion ? Quote Link to comment Share on other sites More sharing options...
dec33162 Posted February 21, 2020 Share Posted February 21, 2020 But did they even check it to see if the issue is with the Bass? As stated, the issue could be with the POD XT Live! Quote Link to comment Share on other sites More sharing options...
fgmarand Posted February 21, 2020 Author Share Posted February 21, 2020 No, they didn't. I guess they don't want to have to spend time diagnosing something for which they won't be able to sell a repair. Quote Link to comment Share on other sites More sharing options...
