Smj7 Posted February 10, 2020 Share Posted February 10, 2020 I’m horrible at this midi stuff, but I’d like to have a button on the Mc6 dedicated to scrolling through the input impedances... is this possible? Or can I only toggle from one to another? Can someone walk me through this? Thanks! Sean Meredith-Jones www.seanmeredithjones.com Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 12, 2020 Share Posted February 12, 2020 I think you're out of luck as far as actively scrolling the input impedance settings goes. You can use Snapshots to change them to accommodate specific devices, but that'a about it AFAIK. Quote Link to comment Share on other sites More sharing options...
jrosenberger Posted February 12, 2020 Share Posted February 12, 2020 You can assign a CC controller to the input impedance and then program the mc6 to cycle through a few settings for it. I haven't done this, but https://www.thegearpage.net/board/index.php?threads/the-unofficial-helix-midi-guide.1954544/ suggests you can. Quote Link to comment Share on other sites More sharing options...
Smj7 Posted April 27, 2020 Author Share Posted April 27, 2020 Hey Folks, I'm revisiting this as I have some time. I want to setup a switch on the MC6 to toggle between 230k and 1M impedance. I have a guitar with Humbuckers and coil taps. The taps are considerably brighter than the Humbuckers. Here's What I've tried: 1) Go To The Impedance parameter in The input section on the Stomp 2) In the menu: select Controller Assign 3) Set Parameter to In-Z Controller: Midi CC CC# shows up as CC4 on the Stomp 4) Turn The page and Set Min Value to 230k (Single Coil) and Max value to 1M Ohm (Humbucker) On The Mc6 1) For Button C I set the Toggle Mode to On 2) Msg 1 Action: Press Type: Control Change 3) Set CC#: 4 Value: 0 4) Msg 2 Action : Press Type: Control Change 5) CC#: 4 Value: 127 6) press "Learn" on the Stomp What happens when I try it: If the In-Z value is on 230k to start, when I try out the action of toggling to 1M.... The stomp's In-Z value goes to Auto. When I toggle the MC6 button again... it doesn't affect the Stomp and it just stays on Auto. There's no toggling going on. Is there something I'm missing? Sean Meredith-Jones www.seanmeredithjones.com Quote Link to comment Share on other sites More sharing options...
Smj7 Posted April 28, 2020 Author Share Posted April 28, 2020 Sigh... Rewatched the Morningstar demo of programming for the Stomp. In the MC6 Midi Editor.... I forgot to distinguish between position 1 and position 2 for each control change. I had them set to both. Hence I could get it to change to one setting but not the other. Rock on. Sean Meredith-Jones www.seanmeredithjones.com Quote Link to comment Share on other sites More sharing options...
