Run 2 Independent Set-Ups - off one Helix?
cr500guy
I’ve had the HD500 in the past and really loved it running to monitors. I used it for amp/cab model/effects patches. But I’ve always had a separate amp and pedal board. Currently I have an EVH amp and HX Effects with the 4 cable method.
My question... is it possible  to run both setups off of one Helix?
So in other words if I was in the mood to play through dual monitors a Pink Floyd patch I could just turn on the Helix and go to the specific Banks with those amp/cab/fx patches.
OR...
If I’m in the mood to play through my EVH amp with banks loaded with patches of effects using the 4 cable method, I could do that.
Is this possible? If it is I will sell my HX Effects and purchase a Helix and just run both setups.
Thanks in advance. :)
14 hours ago, rd2rk said:
Not only can you do both, you can combine them into a W/D/W configuration.
For max flexibility, get the Helix Floor or Rack w/control.
Download the manuals and study the routing features BEFORE purchasing.
So just to be clear. I can have my EVH Amp connected four cable method in pedal mode AND have monitors also connected and make separate patches for each? I wouldn’t have to completely disconnect my EVH amp to switch over from pedal mode to the monitors and go into Amp/cab/effects mode?
Could I do this with the Helix LT? I just ask as it’s a little more budget friendly than the Helix Floor.
Thanks for your help btw!
You can use the 1/4 Out and the fx send/return to connect your amp. And you can connect your monitors to the XLR Outs.
In your patches you can choose the outputs you need(XLR, 1/4, Digital, Multi,...). You can also do this with the LT.
