Keo420 Posted March 9, 2020 Share Posted March 9, 2020 Hi guys, I'm currently using my Pod HD500x as a soundcard for my Studio One 3 (Professional) setup and I'm experiencing an issue where panning tracks does not work. If I pan an audio track to the far left and switch off my left monitor, I still have sound from that track in my right monitor. This is happening since I got my Focusrite Scarlett audio interface, so I assume the issue comes from there. I only using the Scarlett but I can't make it work for some reason. I think I may have unwillingly modified some settings but since I don't know much about DAW technicalities, inputs, outputs, sample rates and stuff, I just wanted to post it here to check if anyone knows what can cause this issue. Thanks for anyone stopping by ! Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted March 9, 2020 Share Posted March 9, 2020 Are you recording a stereo track? Have you tried recording a left or right only track? Is it a balanced sound even if you pan one way 100% or is it only a slight sound in the opposite speaker? Quote Link to comment Share on other sites More sharing options...
Keo420 Posted March 10, 2020 Author Share Posted March 10, 2020 Hey dude, thanks for your reply. Are you recording a stereo track? I'm recording on mono tracks. I always did that without issues before. And when I switch the audio from the HD500x to let's say ASIO driver, the track is well panned and can only be heard from one speaker. Have you tried recording a left or right only track? I'm not sure that I know how to do so. Do you use Studio One ? Is it a balanced sound even if you pan one way 100% or is it only a slight sound in the opposite speaker? Seems like it's slightly off balance, there's a bit more sound in the speaker where the track is panned to. When I play both tracks (1 panned L and one panned R) with this issue, the result is weird, it sounds like a phaser or flanger effect (while there are only comp and eq inserts). Quote Link to comment Share on other sites More sharing options...
Keo420 Posted March 11, 2020 Author Share Posted March 11, 2020 I downloaded and installed the latest driver for the POD HD500x yesterday, I still have the issue where I can't pan my tracks. Quote Link to comment Share on other sites More sharing options...
