themetallikid Posted March 15, 2020 Share Posted March 15, 2020 I have a preset where I utilize 2 delays one for a simple fill lead line and another for the main solo, each one triggered by something else. The main solo is triggered via snapshot changes, the lead line (because i'm singing) is triggered by rocking Exp 1 backwards past 97%. When trying to assign the snapshot Delay block to bypass via Snapshots...its not an option to choose....?? I'm lost. I've deleted the block, entered it again, I've copied/pasted the other delay block intending to only change the bypass trigger from Exp 1 to Snapshots. Any ideas? Quote Link to comment Share on other sites More sharing options...
themetallikid Posted March 15, 2020 Author Share Posted March 15, 2020 Not sure what i did, but I held the Bypass button thinking there'd be a menu I'd find on the Helix itself..and an icon appeared in upper right corner next to the snapshot number. I can't make out what it says or looks like, but it seems to allow me to assign the bypass by snapshot now. IDK....lol Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 15, 2020 Share Posted March 15, 2020 Snapshots isn’t an option as a bypass assignment. The bypass states of blocks will be recalled by snapshots when you load them, but that happens automatically (there is the Snapshot Bypass parameter now that allows you to disable this behavior - the bypass state of blocks where you have this unchecked will remain unaffected by snapshots changes). I think you were confusing controller assign with bypass assign in your first post. Quote Link to comment Share on other sites More sharing options...
themetallikid Posted March 15, 2020 Author Share Posted March 15, 2020 I might be verbally, but procedurally I wasnt doing anything different. In HX Edit....add Delay block, go to the controller page (you're right) and select bypass, choose Snapshots. I even looked at a different block and it was listed. Again, maybe I did something different, but I'm fairly fluent and have done this enough times. I got it fixed so I'm not overly concerned at this point, more confused as I've ran into that sometimes previously, but somehow figured it out. lol. I recently did a 7 & 8 backup/restore of my setlists/presets from a corrupted slot while importing presets to build setlists for next week. Upon bootup, it had to rebuild all my presets, I went to grab a beer, came back...it was ready to go, I realized that this preset would benefit from a 2nd delay block (doing the same thing as the 1st one, but controlled differently to help me not look awkward while trying to sing, transition into a lead snapshot sound and still play the lead fine). I made room in the preset, copy/pasted the block 1st to the 2nd block, and just was going to change the bypass assignment from Exp 1 to Snapshots and it wasnt listed there. Quote Link to comment Share on other sites More sharing options...
