pavelds Posted April 12, 2020 Share Posted April 12, 2020 Hi guys, any ideas how to do this? It looks like by default it comes with 48 KHZ but my Protools project is in 44.1 KHZ. I can't see anything online re-sample rate change in the HX Stomp... Cheers Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted April 12, 2020 Share Posted April 12, 2020 To use HX Stomp as an audio interface at sample rates other than 48kHz, you'll want to install the HX Stomp driver, available here: http://line6.com/software/ Quote Link to comment Share on other sites More sharing options...
pavelds Posted April 12, 2020 Author Share Posted April 12, 2020 3 hours ago, Digital_Igloo said: To use HX Stomp as an audio interface at sample rates other than 48kHz, you'll want to install the HX Stomp driver, available here: http://line6.com/software/ Hi there, I go to that link but I can't see the HX Stomp Driver, any chance on publishing the actual link? Thanks Quote Link to comment Share on other sites More sharing options...
qwerty42 Posted April 12, 2020 Share Posted April 12, 2020 I mean this in the nicest way possible, but... did you even look?... To make up for my snarkiness, here are your links: ;) HX Stomp Driver: https://line6.com/software/readeula.html?rid=9135 HX Edit / HX Update Driver: https://line6.com/software/readeula.html?rid=8830 Quote Link to comment Share on other sites More sharing options...
pavelds Posted April 14, 2020 Author Share Posted April 14, 2020 Thanks for the links man, I wasn't clicking on "go" after selecting.... Anyway, problem solved once I updated the HX Stomp with the driver, Protools allows me now to choose between 44.1 and 48. Thanks again :) 1 Quote Link to comment Share on other sites More sharing options...
Smj7 Posted April 16, 2020 Share Posted April 16, 2020 Can the Stomp’s sample rate be changed in Hx Edit or the unit itself?... or is it Pro Tools that gives you that option? Sean Meredith-Jones www.seanmeredithjones.com Quote Link to comment Share on other sites More sharing options...
