WildVines Posted April 23, 2020 Share Posted April 23, 2020 I have a Variax 700 acoustic and the volume of the low E-string is much lower than the others. It was also producing static noise. Any idea of the problem and possible fixes would be appreciated. Thank you, Craig Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 26, 2020 Share Posted April 26, 2020 The saddle is the chassis ground, there's probably some dirt in between. Cotton swab, 70% isopropyl alcohol,... drip it into the saddle, blow out dry with canned air. If that doesn't do it, there's a deeper problem and will need to be service by a Line 6 authorized service center. Quote Link to comment Share on other sites More sharing options...
WildVines Posted April 26, 2020 Author Share Posted April 26, 2020 Thank you for the info. I also noticed that the D string is a lot louder than the others. Could this be the same problem? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 26, 2020 Share Posted April 26, 2020 Yes. Quote Link to comment Share on other sites More sharing options...
WildVines Posted May 20, 2020 Author Share Posted May 20, 2020 I tried the cleaning procedure, but no luck. The previous owner told me I could fix this using the Workbench software. Is this true? Is the software still available and how do I connect the guitar? Thanks Quote Link to comment Share on other sites More sharing options...
psarkissian Posted May 21, 2020 Share Posted May 21, 2020 Yes it can help. Yes, original Workbench is still available, check the Downloads page for compatibility, as ti may not work for more recent computer OS'. Best bet, take it in for servicing at a Line 6 authorized service center. they can check and if need be, replace the piezo. Quote Link to comment Share on other sites More sharing options...
cepyih Posted June 14, 2020 Share Posted June 14, 2020 Same thing happened to me. I replaced the Peizo and all was fixed. Quote Link to comment Share on other sites More sharing options...
