optofonik Posted May 6, 2020 Share Posted May 6, 2020 In the real world I use two clean Laney Cub 12s miced with two Sennheiser e906s for a stereo rig and would like to replicate their sound, as close as is reasonable, on the HX Stomp. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted May 6, 2020 Share Posted May 6, 2020 This is a big guess but try the Vox AC-15 and experiment with various speaker cab/mics. You may not want to use 2 amps since it will limit your blocks and DSP. One thing people do is one amp but two different cabs. You could try that. Quote Link to comment Share on other sites More sharing options...
optofonik Posted May 6, 2020 Author Share Posted May 6, 2020 Wouldn't a single amp and two cabs take three blocks instead of just two that a dual combo setup would utilize? Quote Link to comment Share on other sites More sharing options...
brue58ski Posted May 6, 2020 Share Posted May 6, 2020 1 hour ago, optofonik said: Wouldn't a single amp and two cabs take three blocks instead of just two that a dual combo setup would utilize? I believe you can have 1 amp and 2 cabs in one block. It's been awhile since i've done that. But the DSP usage will be large. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted May 6, 2020 Share Posted May 6, 2020 Looks like it's more, two blocks. One for the amp and the other can be a dual cab block. So you'd only need two blocks. I thought you could just have one block that has an amp and dual cabs but I guess not. I'm not at home so this is all by memory and looking at the manual. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 6, 2020 Share Posted May 6, 2020 Depends. The dual cab block isn't stereo. Effects placed between amp and cab would have to be mono, or would sum to mono. If you want stereo cabs you'd need three blocks, with one of the cabs in a split path. You could then put stereo effects before and after the cabs/split. Quote Link to comment Share on other sites More sharing options...
