CarsonGrey 0 Posted May 19, 2020 Hello everyone ! I have some questions about The amplifi. I want to buy an amplifi 150 for my electric guitar and it looks great because i also need bluetooth speakers for my room for a long time. But i would also like to control Speed Test Solitaire essay writer the effets of The amplifi with pedals so i thought it could be nice to buy also the fx100. My question is, is it a good idea ? (I need bluetooth speakers), and is it possible to play with both? And which one will i connect with The amplifi remote app ? What’s your opinion about this. My budget is 500 euros. Thanks in d’avance ! Quote Share this post Link to post Share on other sites
Triryche 2,610 Posted May 19, 2020 An Amplifi 150 and FX100 would be redundant. You would not be able to control the 150 with FX100. You can connect only to one hardware at a time. If it were me, I would look into the POD Go, it is based on their current flagship processor Helix and can do so, so, so much more and is strongly supported. Quote Share this post Link to post Share on other sites
RileyVallance19 5 Posted May 20, 2020 Hi Carson, Like Triryche said, you won't be able to control the AMPLIFi from the FX100. I would recommend the FBV Shortboard MkII or FBV 3. They are designed as foot controllers for the AMPLIFis and Spiders. I habe an AMPLIFi 150 and the FBV Shortboard MKII and they work great together. Alternatively, you could also get a different effects processor and use it with the AMPLIFi like Triryche said, but then all the effects on the AMPLIFi would be redundant and you still wouldn't be able to control them. I also have a POD HD500X which I use in conjunction with the AMPLIFi, using effects from both. But I still use my Shortboard to control the AMPLIFi. Overall, I would look into getting a FBV pedal because they will do what you want them to do. I hope this helps! Quote Share this post Link to post Share on other sites
cbrillow 32 Posted May 21, 2020 IMO, if you’re not planning to gig with a band, the 150 is overkill. For home use or even a small place like a coffee shop, the 30 would do the job, and it sounds really good. And pair it with the FBV as the previous poster mentioned for great flexibility in selecting presets on the fly. I picked up a used FBV Shortboard MK II, and it works great! Quote Share this post Link to post Share on other sites
WigglyBirdie 0 Posted August 11, 2020 On 5/20/2020 at 6:47 AM, RileyVallance19 said: Hi Carson, Like Triryche said, you won't be able to control the AMPLIFi from the FX100. I would recommend the FBV Shortboard MkII or FBV 3. They are designed as foot controllers for the AMPLIFis and Spiders. I habe an AMPLIFi 150 and the FBV Shortboard MKII and they work great together. Alternatively, you could also get a different effects processor and DQFanSurvey use it with the AMPLIFi like Triryche said, but then all the effects on the AMPLIFi would be redundant and you still wouldn't be able to control them. I also have a POD HD500X which I use in conjunction with the AMPLIFi, using effects from both. But I still use my Shortboard to control the AMPLIFi. Overall, I would look into getting a FBV pedal because they will do what you want them to do. I hope this helps! Great idea man thanks keep it up all the time. am very happy to see your standard. Quote Share this post Link to post Share on other sites
