lalmassy Posted June 4, 2020 Share Posted June 4, 2020 HX Stomp setup with two (2) primary presets. Each preset has three (3) Snapshots. Set to Snapshot mode. - Preset 1 acts as rhythm channel - - Snapshot 1 (clean), Snapshot 2 (w/reverb), Snapshot 3 (w/reverb and drive) - Preset 2 acts as lead channel - - Snapshot 1 (clean), Snapshot 2 (w/reverb), Snapshot 3 (w/reverb and drive) Using Mission Engineering two button switch to change presets. When I change between presets the Snapshot returns to 1 instead of staying on the Snapshot I was last using. Can this be changed? Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 5, 2020 Share Posted June 5, 2020 The snapshot that loads when you load a preset is whatever one was active when you saved the preset. Not really any way around that. 1 Quote Link to comment Share on other sites More sharing options...
chicpurple Posted June 5, 2020 Share Posted June 5, 2020 9 hours ago, phil_m said: The snapshot that loads when you load a preset is whatever one was active when you saved the preset. Not really any way around that. quite clear answer Quote Link to comment Share on other sites More sharing options...
MrPhasetone Posted December 5, 2024 Share Posted December 5, 2024 I would also use a feature like this. Hope it will come in the next update. Quote Link to comment Share on other sites More sharing options...
