Noise on 1/4 Output only
urimish
I've been noticing a lot of electrical static noise from my Helix, when plugged via 1/4' to the mixer. Same setup using XLR eliminates 90% of the noise.
Anyone encountered something similar? Can/Should I clean the 1/4 output port somehow?
My unit is out of its warranty period, BTW
Thanks!
Are you using a quality EMI/RFI Filtered Surge Suppressor type power strip on all devices?
Are you using long cable runs (unbalanced is USUALLY good up to 20')?
Are you using quality shielded cables? Are they old or worn?
Is the wall outlet you're using on the same circuit as major appliances?
Are you within 10' of a router or other wireless devices on either end or in between?
Cell phone nearby or in your pocket while playing?
I'm using new, high-quality shielded cables, but some of these questions need to be checked - thanks.
However (please correct me if I'm wrong) , if that were the cause I would expect some of the noise to remain even when I connect to the mixer via XLR .The noise is practically eliminated when i use the XLR output instead of the 1/4' output, so It looks to me like there could be something in the 1/4 output jack causing noise.
Has anyone seen something similar with their Helix?
When using the 1/4" outs you are running an unbalanced signal. With XLR, you are running a balanced signal. A balanced cable run carries two copies of the signal out of phase with each other. The mixer then flips the phase on one copy before summing them back together. This means it will auto-cancel any noise/interference picked up in the cable run. The most likely thing at play here is that your unbalanced 1/4" cable is picking up a ton of electrical interference. Technically, your XLR is also picking up all the same interference but it's getting canceled back out by the phase shift. Or maybe you've got a grounding problem.
