bhagmeister Posted June 19, 2020 Share Posted June 19, 2020 Newbie here. Looking to use downloaded CustomTones on my Helix (floor) with new PC+. Would like to use PC+ Speaker models and know I need to disable or remove CAB modeling inside any Helix preset. Is there a global way for Helix to do this? I realize DSP resources are committed with each CAB model programmed. It would be great for either Helix to disable CAB when L6'd to PC+ - OR - for some Helix Edit utility to edit presets to replace AMP-CAB with either AMP or Pre-Amp on command. btw, I tried to replace AMP-CAB with like AMP inside a Helix preset but I notice that (AMP) settings are not preserved. Would be great to have that option so as to make PC+ (Speaker Modeling) use easier. rob Quote Link to comment Share on other sites More sharing options...
amsdenj Posted June 22, 2020 Share Posted June 22, 2020 The Helix patch and have complete control of the Powercab settings. You don't need a cab model or IR in Helix unless you are using Powercab in FRFR mode. This is of course useful if you are using acoustic instruments in Helix. But I also continue to use a few IRs in my Helix patches even with a Powercab 212 in FRFR mode. It just works better in some cases. If you're ok editing JSON, you can edit the Helix prefix with a text editor to change from AMP+Cab to AMP without loosing you're amp settings. Quote Link to comment Share on other sites More sharing options...
bhagmeister Posted June 23, 2020 Author Share Posted June 23, 2020 Thank you! Editing in JSON may very well be the ticket. rob Quote Link to comment Share on other sites More sharing options...
bhagmeister Posted June 24, 2020 Author Share Posted June 24, 2020 Which text editor do you use? I'm on a macOS computer and am having trouble finding an editor that recognizes .hlx files. thanks rob Quote Link to comment Share on other sites More sharing options...
OmniFace Posted July 25, 2020 Share Posted July 25, 2020 The only programs that will recognize .hlx are Line 6 programs. Just edit the file extension to .json before editing the file. Then rename it back to .hlx when done. If you can use a PC, you can just force it to be opened in a program with right click > open with Quote Link to comment Share on other sites More sharing options...
Belew01 Posted August 5, 2020 Share Posted August 5, 2020 Also, if you haven't already, search Powercab on customtone. There are some patches already made with amp only. Some are quite good. Quote Link to comment Share on other sites More sharing options...
