phobos1223 Posted June 29, 2020 Share Posted June 29, 2020 I have a problem with the volumen pedal, if I move it all, all the drive parameter of the cabinet is moved automatically to 50%. I updated the firmware to the 1.30 v and also downgraded to the original version, but the problem was not fixed. Even the pedal calibration was done. You can see the problem on the video. does any body has the same problem? Is there any solution available? Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted June 29, 2020 Share Posted June 29, 2020 Check of you have any tweak on , on the volume or other settings Quote Link to comment Share on other sites More sharing options...
phobos1223 Posted June 30, 2020 Author Share Posted June 30, 2020 I did, but the problem is for all the presets, even with the factory settings. Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted June 30, 2020 Share Posted June 30, 2020 After a factory reset, YOU NEED to remake a pedal calibration! You did it? Factory reset don't reset your pedal calibration ! Quote Link to comment Share on other sites More sharing options...
