schweidler Posted July 4, 2020 Share Posted July 4, 2020 Good day. My name is Dieter and I am new here in the forum. I have a problem connecting my new PODGO to my 8 year old PC. The device is recognized but the driver is not working properly. I have installed the latest windows 10 software and the POD GO has been updated to the latest firmware. Maybe someone has an idea or can send me a suitable driver? thank you Quote Link to comment Share on other sites More sharing options...
spaceatl Posted July 6, 2020 Share Posted July 6, 2020 That look like the driver is NOT installed. Go to the software page and insure you have installed the driver. It is a separate item in the downloads. https://line6.com/software/index.html IE: Drivers Line 6 Driver2 Version 1.94.0.0 Released 3/31/20 Works with: POD Go Quote Link to comment Share on other sites More sharing options...
schweidler Posted July 6, 2020 Author Share Posted July 6, 2020 Hi, thanks for your awnser but the curent driver is already installed. I don't know where the problem is...... Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 6, 2020 Share Posted July 6, 2020 Your screenshot indicates that, as spaceatl said, you do not have the Line 6 driver installed. You highlight a 'Standard USB Hostcontroller'r; that's not the correct driver. The correct driver should have been installed with the POD Go Edit download package. If you haven't downloaded and installed that program you should do so. Also, I notice that you have a Logitech Webcam device installed. Logitech and Line 6 drivers can sometimes conflict. Try temporarily disconnecting your webcam to test. Quote Link to comment Share on other sites More sharing options...
schweidler Posted July 6, 2020 Author Share Posted July 6, 2020 Hello, so i disconnected de Logitech,....no result,.... and I installed the POD GO Edit and the Drivers.....it wont find the unit. so i think my computer ist to old,...... Thanks all for trying to help me but i should have a look for a new Laptop.... Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 6, 2020 Share Posted July 6, 2020 If your computer is able to run Windows 10 it is able to run POD Go Edit. Try different USB ports on your computer, especially the ports on the back panel not the front panel. Avoid using a USB hub, such as the internal hidden ones behind the computer’s front panel. Try a different USB cable. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted July 7, 2020 Share Posted July 7, 2020 My German is really rusty, but I thought that meant Unknown Device....that generally means that the driver is NOT loaded properly. I just want to ask if you downloaded the Driver separate and re-installed it? Quote Link to comment Share on other sites More sharing options...
schweidler Posted July 7, 2020 Author Share Posted July 7, 2020 Hi,....yes i already tried all different USB ports, installed the POD GO edit software and Driver a thew times,...but without success..... also tried to install and reinstall the drivers, manuel installing the drivers,...remove all and install new startet the Line 6 License manager an registerd the device.... Today i trie it on an other Laptop Thank you spaceatl and silverhead for your awnsers ! Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 7, 2020 Share Posted July 7, 2020 I suggest you open a support ticket if you haven’t already done so. Quote Link to comment Share on other sites More sharing options...
