foofighterux2
Weird issue with podfarm 2.5
podfarm vst in ableton and logic x will not work with shortboard mk11.what ive discovered is that if I open ableton and arm an audio track then open podfarm standalone I can hear for example the distortion. I can record it in ableton  but when I play it back the tone is clean.if  I then drop vst podfarm on that track with same setting as standalone ie:comfortably numb it works.all I want to do is use shortboard mk11 to control presets up and down and wah.i can set wah to work vst but not presets.can anyone please  tell me how to set up scrolling in vst podfarm 2.5?
Standalone works with podfarm  and amplitube but not in ableton  or lo
gic x many thanks guys.
I read on here about licence  for podfarm 2.5 is only active with ux2?
I have axe io ik multimedia.will vst podfarm not work with axe io in ableton for example thank you?
PF2 should work as a plug-in in your DAW if the UX2 is connected and recognized. To use PF2 standalone with a non-Line6 interface would require the hardware independent license.
