drryan Posted August 17, 2020 Share Posted August 17, 2020 Hi, Does anyone use the Variax tuning to drop the low E and A strings down one octave? I do, and it works great to enable bass lines under the treble strings. My question is, I’m getting a helix lt and my goal is to create presets with clean bass out one output, with say, dirty chords out a different output. I’d appreciate some feedback as to where to go for setting up performance presets, Are there any jtv/ helix preset designers who know what I’m talking about? Thank you, good people. DR Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 29, 2020 Share Posted August 29, 2020 The Helix Marketplace contains many presets created by pros. Explore those options. Perhaps one or more of those creators will consider building custom presets for you. Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 29, 2020 Share Posted August 29, 2020 Also, as of firmware v2.80 Helix supports Variax string level settings. You could create a dual input preset, set both inputs to Variax, set the treble string levels to zero on the clean bass path, leave the levels normal for the dirty chord path, and independently process the paths/strings. Set the path outputs differently as desired. Quote Link to comment Share on other sites More sharing options...
drryan Posted September 3, 2020 Author Share Posted September 3, 2020 Thanks. Quote Link to comment Share on other sites More sharing options...
