IsraelDoughlas Posted September 17, 2020 Share Posted September 17, 2020 Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 17, 2020 Share Posted September 17, 2020 First, you should download and install POD Go Edit. Hot Check for Updates and install the latest update. After you do that, you should do a factory reset. Hold down footswitches C & D while powering up, and that will reset everything. The factory presets should show up then. 1 Quote Link to comment Share on other sites More sharing options...
voxman55 Posted September 22, 2020 Share Posted September 22, 2020 Hi @IsraelDoughlashow did you get on? If a reset didn't work and you are still having a problem I have a Backup of all the Pod Go factory patches that you can import via Pod Go Edit. Send me your email and I'll send to you. Quote Link to comment Share on other sites More sharing options...
cristt Posted September 23, 2020 Share Posted September 23, 2020 Also, be sure you are in the factory preset folder. Maybe by chance you are browsing the user folder (empty by default). 1 Quote Link to comment Share on other sites More sharing options...
kaixin Posted March 16, 2022 Share Posted March 16, 2022 On 9/23/2020 at 4:00 AM, voxman55 said: Hi @IsraelDoughlashow did you get on? If a reset didn't work and you are still having a problem I have a Backup of all the Pod Go factory patches that you can import via Pod Go Edit. Send me your email and I'll send to you. same problem Quote Link to comment Share on other sites More sharing options...
