Voltage adapters
Nylander88
The adapter you suggested doubles the voltage (by connecting two voltage source in series). Don't use that. You need 9V for the HX Stomp not 18V or 24 V. Some 9V pedal power supplies offer multiple isolated outs with 500mA max each. For those iit is possible to connect them in parallel to sum the available current (i.e. 500mA + 500mA =1000mA = 1A).
Awesome, I think it's time for your "Iknowathingortwo" badge needs to be upgraded. Can't have a smarter person with the same Badge as me lol
  • Haha 1
https://www.long-mcquade.com/15778/Guitars/Cables_Power_Supplies/Voodoo_Lab/Current_Doubler_Adapter.htm
Hey would this work? It's a current doubler (I would assume amps?) The other one was a voltage doubler
Current is measured in ampere, right. That adapter has a jack. You would need a plug:
https://www.logsdonaudio.com/cables/strymon-power-supply-and-line-6-pedal-current-doubler-cable
Only use with a 9V power supply!
