tribal123 Posted November 1, 2020 Share Posted November 1, 2020 I have a Pod Hd desktop version and i would like to know how to connect to a normal mixer, can be made through normal cable from Left Output ? Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted November 1, 2020 Share Posted November 1, 2020 sure... if the mixer has that kind of jack. Most do, but some do not. but why the left. how about the right? Quote Link to comment Share on other sites More sharing options...
tribal123 Posted November 1, 2020 Author Share Posted November 1, 2020 16 minutes ago, pianoguyy said: sure... if the mixer has that kind of jack. Most do, but some do not. but why the left. how about the right? I assume that left channel is the default, am i wrong? Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 1, 2020 Share Posted November 1, 2020 Since the POD HD is a stereo output device it would be best to connect both the L and R outputs to your mixer. I don’t think that the signal collapses to mono if you only use the L output. If you want to use just the L output make sure you place a mono FX block at the end of the signal chain. That will force a collapse to mono. Quote Link to comment Share on other sites More sharing options...
