zappazapper Posted November 19, 2020 Share Posted November 19, 2020 https://line6.ideascale.com/a/dtd/Mix-control-for-all-effects-blocks/898131-23508 I was gonna create a new post on IdeaScale but I found this. This is one of those things that you get used to having when you're a Reaper user, and don't realize how useful it is until you don't have it. UPVOTE IT NOW!! XD 1 Quote Link to comment Share on other sites More sharing options...
codamedia Posted November 19, 2020 Share Posted November 19, 2020 Although many effects do have the mix/blend control, you are right... many still don't. A mix/blend control is parallel processing built into every effect that has it.... extremely powerful without the need of using precious space on the parallel path. Upvoted! Quote Link to comment Share on other sites More sharing options...
roscoe5 Posted November 19, 2020 Share Posted November 19, 2020 I would love a mix control on all distortion pedals. I like to run tube screamers and drive pedals in parallel with a straight signal path in the input of a dirty amp. Way more depth and you retain more amp sound. Plus when I do this, I can't have parallel cabs on path 1A. I have to map to Path 2A and put my cabs down there. I know I can do a single dual cab block, but I like to put a little verb on the "room mic" cab Upvoted and commented Quote Link to comment Share on other sites More sharing options...
