dacop13 Posted November 25, 2020 Share Posted November 25, 2020 Does anyone else here use Preamps only? I run through an Orange Pedal Baby and a real 2x12 cabinet and find the preamps sound much better. Just wondering if others use the preamps. Quote Link to comment Share on other sites More sharing options...
codamedia Posted November 25, 2020 Share Posted November 25, 2020 Yes, quite regularly. If the power amp section of an amp is not a big part of the behavior/tone of that amp, I will often just use the pre-amp versions. I tend to get a beefier tone from the pre-amps alone. There are notable exceptions... VOX Amps and Tweed amps in particular require the full amp models and I also prefer the PLEXI that way. My current live rig is based around a Deluxe Normal Channel pre-amp and a Celestion Ruby IR. I'm experimenting with replacing the Deluxe with the new Princeton pre-amp and it's sounds great (better) here in my studio, but there are no gigs to test it in right now. For reference... I go direct to FOH/Monitors and also an FRFR when needed. Quote Link to comment Share on other sites More sharing options...
themetallikid Posted November 25, 2020 Share Posted November 25, 2020 so, you use just the 'preamp' only version direct to FOH? Quote Link to comment Share on other sites More sharing options...
codamedia Posted November 25, 2020 Share Posted November 25, 2020 26 minutes ago, themetallikid said: so, you use just the 'preamp' only version direct to FOH? Was that directed to me or @dacop13? I run the Deluxe Normal Channel (or the new Princeton) preamp model into a Celestion Ruby IR, direct to FOH/Monitors/FRFR. Others may feel very different. This is just my preference. Quote Link to comment Share on other sites More sharing options...
dacop13 Posted November 26, 2020 Author Share Posted November 26, 2020 2 hours ago, codamedia said: Yes, quite regularly. If the power amp section of an amp is not a big part of the behavior/tone of that amp, I will often just use the pre-amp versions. I tend to get a beefier tone from the pre-amps alone. There are notable exceptions... VOX Amps and Tweed amps in particular require the full amp models and I also prefer the PLEXI that way. My current live rig is based around a Deluxe Normal Channel pre-amp and a Celestion Ruby IR. I'm experimenting with replacing the Deluxe with the new Princeton pre-amp and it's sounds great (better) here in my studio, but there are no gigs to test it in right now. For reference... I go direct to FOH/Monitors and also an FRFR when needed. Agreed in the "beefier tones", same here. Quote Link to comment Share on other sites More sharing options...
dacop13 Posted November 26, 2020 Author Share Posted November 26, 2020 29 minutes ago, codamedia said: Was that directed to me or @dacop13? I run the Deluxe Normal Channel (or the new Princeton) preamp model into a Celestion Ruby IR, direct to FOH/Monitors/FRFR. Others may feel very different. This is just my preference. Sure, this makes sense. As long as you add an IR or Cab with that Preamp, FOH will be fine. Quote Link to comment Share on other sites More sharing options...
dacop13 Posted November 26, 2020 Author Share Posted November 26, 2020 Also would like to add, preamps sound even better when going through a tube amp's return. 1 Quote Link to comment Share on other sites More sharing options...
themetallikid Posted November 26, 2020 Share Posted November 26, 2020 Yes it was directed at both really....I'll have to play around with it. Thanks for the tip 1 Quote Link to comment Share on other sites More sharing options...
