gerardmin Posted November 28, 2020 Share Posted November 28, 2020 Hi, I just update my HX Stomp to 3.0 and once done, all presets name disappear and rplaced by "New Preset". Did someone got the same issue and how can find a list of the 3.0 preset list? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 28, 2020 Share Posted November 28, 2020 54 minutes ago, gerardmin said: Hi, I just update my HX Stomp to 3.0 and once done, all presets name disappear and rplaced by "New Preset". Did someone got the same issue and how can find a list of the 3.0 preset list? Thanks for any help. Hi, Just before updating to version 3.00 you should have made a back up of the presets that were in your HX Stomp, and you can choose to restore them from within HX Edit. First thing to check is that you do actually have HX Edit v.3 and not an earlier version. You can perform a factory reset on your Stomp which will update with the latest presets. These are the reset options. Hold down the combination of Foot Switches while turning on the power to your Stomp. Recommend FS1+2 and see how it goes. HX Stomp Button Combination Description All 3 Footswitches Clears all presets/IRs FS1+2 Resets presets and IRs FS 2+3 Factory restore (globals, presets, IRs Hope this helps/makes sense. 3 Quote Link to comment Share on other sites More sharing options...
coccoslash Posted December 1, 2020 Share Posted December 1, 2020 Hi, I've just updated my HX Stomp. Same problem here: 1) Brand New HX Stomp 2) Update 3.0 3) All names "New Presets" It's not a matter of backup Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 1, 2020 Share Posted December 1, 2020 1 hour ago, coccoslash said: Hi, I've just updated my HX Stomp. Same problem here: 1) Brand New HX Stomp 2) Update 3.0 3) All names "New Presets" It's not a matter of backup Just do a factory reset - hold down FS2 and FS3 while powering up. If you’ve not created any presets yet, you don’t need to do anything else. 1 Quote Link to comment Share on other sites More sharing options...
coccoslash Posted December 1, 2020 Share Posted December 1, 2020 19 hours ago, phil_m said: Just do a factory reset - hold down FS2 and FS3 while powering up. If you’ve not created any presets yet, you don’t need to do anything else. Thanks, It works :-) Quote Link to comment Share on other sites More sharing options...
StickyDingo Posted April 27, 2022 Share Posted April 27, 2022 Just confirming that this is still an issue in April of 2022. I bought a new HX Stomp and powered it up to find all presets named 'New Preset'. Nothing in the box about this issue so I googled it and found this post. Factory reset did the trick. Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 27, 2022 Share Posted April 27, 2022 On 4/27/2022 at 9:20 PM, StickyDingo said: Just confirming that this is still an issue in April of 2022. Hi, It’s not an “issue”, it is a know consequence of not following the firmware update procedures as mentioned in the release notes. I would guess that possibly more than 90% of “issues” are avoidable by the user. This thing is so common that it really should have it’s own “sticky”, similar to this one: Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 27, 2022 Share Posted April 27, 2022 On 4/27/2022 at 3:20 PM, StickyDingo said: Just confirming that this is still an issue in April of 2022. I bought a new HX Stomp and powered it up to find all presets named 'New Preset'. Nothing in the box about this issue so I googled it and found this post. Factory reset did the trick. I believe retailers and/or distributors often update the firmware on units they have in their stock, but they forget to do the factory reset after doing it. 1 Quote Link to comment Share on other sites More sharing options...
