regalpierot Posted November 29, 2020 Share Posted November 29, 2020 So I updated my Stomp to 3.0. Went great. Browsed through to add one of the new effects, all greyed out. Suspected it was a DSP limit, started a brand new patch with nothing in the chain....greyed out again when I try to add any of the Poly etc. So, plan B, loaded up HX Native where DSP shouldn't be an issue, and boom....the poly etc effects are greyed out. What be happening? Anyone else seeing this? Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted November 29, 2020 Share Posted November 29, 2020 Now that's pretty weird, really. No idea, sorry (especially as it doesn't seem to work for you in HXN, either). Quote Link to comment Share on other sites More sharing options...
codamedia Posted November 29, 2020 Share Posted November 29, 2020 57 minutes ago, regalpierot said: So, plan B, loaded up HX Native where DSP shouldn't be an issue, and boom....the poly etc effects are greyed out. What be happening? Anyone else seeing this? Native is not wide open by default.... it is likely running in compatibility mode. Even in Floor/LT/Rack mode each path is no more powerful than the Stomp is.... you just get two of them to work with. Click on the gear icon at the lower right corner of native Choose the "hardware compatibility" tab. Choose the mode you want to run it in, or turn if off so their are no limits imposed. If you want your choice remembered.... set it as the default or it will revert the next time you open it. 57 minutes ago, regalpierot said: Suspected it was a DSP limit, started a brand new patch with nothing in the chain....greyed out again when I try to add any of the Poly etc. That doesn't make sense! A blank chain should be able to take ANYTHING as it's first entry. Quote Link to comment Share on other sites More sharing options...
lou-kash Posted November 29, 2020 Share Posted November 29, 2020 53 minutes ago, regalpierot said: started a brand new patch with nothing in the chain....greyed out again when I try to add any of the Poly What happens if you edit the preset on the Stomp, without connecting it to the computer? Quote Link to comment Share on other sites More sharing options...
