Karma180 Posted November 30, 2020 Share Posted November 30, 2020 Hi, so I have this groovy pedal called Freqout in front of my POD HD500X and can hold it down for long feedback effects, there's even a setting for an infinite feedback. I'd like to be able to set up a patch on both my 500x and my ProX that has a stomp button that can do a similar simulated feedback effect; maybe using pitch glide or something. Has anyone done this with success; its gotta sound good :) Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted November 30, 2020 Share Posted November 30, 2020 no Quote Link to comment Share on other sites More sharing options...
hurghanico Posted November 30, 2020 Share Posted November 30, 2020 You can build a Simulated Feedback Patch by yourself if you follow the suggestions given below here: (copied form here: https://line6.com/support/topic/4542-how-use-pitch-harmonic-pod-hd-500/?do=findComment&comment=40034) Effect type Pitch --> Pitch Glide Place right after noise gate and before any other effects or amps. Turn on in FX tab of HD Edit and set pitch to +12 for one octave up. Go to Controller tab and set Pitch Glide mix to Exp 1 or 2, min 0, max 100. Now when playing with heel down you get your normal tone, when you go toe down it jumps one octave giving you that pinch harmonic/feedback effect.. You can add a compressor to get a longer sustain _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
theElevators Posted December 17, 2020 Share Posted December 17, 2020 Or just add an extra distortion pedal, so that when needed you can turn on that extra extra high gain. I played a gig this summer without even using a cabinet--straight into a PA and go amazing feedback for those dramatic rock guitar codas etc. Let your guitar feed back naturally from the PA/monitors, as applicable. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted December 17, 2020 Share Posted December 17, 2020 Sometimes I wonder if the term feedback means the same thing to some people as it does the rest of the world. Quote Link to comment Share on other sites More sharing options...
