erick1337 Posted December 21, 2020 Share Posted December 21, 2020 I'm attempting to record from a YPT-320 keyboard directly via Keyboard's Headphone Out -> UX2 Input. Listening through Stereo Monitor In -> Headphone out sounds great, but even if I remove everything in the POD Farm line (raw signal) and plug into Instrument Input or Line Input, the audio sounds much lower quality, almost "muffled" in a sense. Any ideas as to why this is happening or what I can do to fix it? Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted December 22, 2020 Share Posted December 22, 2020 What are you using for cable/adapters? The keyboard's stereo headphone output is TRS. The UX2 is mono, TS. For best sound from the keyboard, you would want to use a splitter adapter to go from stereo TRS to 2 X mono (left and right). Unfortunately, the UX2 does not have 2 1/4" inputs you can use (the 2nd guitar one has a pad on it), so going from the left and right splits, you would probably need to adapt from TS to XLR and use the mic inputs (this could create noise or clipping issues). Quote Link to comment Share on other sites More sharing options...
Triryche Posted December 22, 2020 Share Posted December 22, 2020 Actually the UX2 has 2 Line Ins. Create a dual tone blank patch and select Line1 for A and Line 2 for B and pan hard L & R. You will need the TRS to 2 X mono cable that fflbrgst mentioned. Quote Link to comment Share on other sites More sharing options...
erick1337 Posted December 22, 2020 Author Share Posted December 22, 2020 Thanks for the responses, I thought Stereo Out -> Mono In wouldn't matter since in PodFarm it will just duplicate the output to the other channel if I plug it into just one of the Line Inputs and Select Line 1 (or 2) as the input, it won't use both unless you select "Line Stereo". I will get the cable and try it out though, I'm assuming you both meant something like this? https://www.amazon.com/Hosa-STP-204-Insert-Cable-Meters/dp/B000068O1Q. Quote Link to comment Share on other sites More sharing options...
Triryche Posted December 22, 2020 Share Posted December 22, 2020 Yes that is the cable. You're KB is stereo so just duplicated one mono channel you are missing half the sound. Do you have Line outs on the KB or just the Headphone out? Quote Link to comment Share on other sites More sharing options...
erick1337 Posted December 22, 2020 Author Share Posted December 22, 2020 Ah I see, that makes sense, especially since the input that sounds fine is specifically the UX2 "stereo monitor in". The KB has no line outs, just stereo headphone out. I think it's odd that my KB is even stereo output though, the sound coming from the left and right earphones sound the same to me. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted December 27, 2020 Share Posted December 27, 2020 On 12/22/2020 at 3:29 PM, erick1337 said: Ah I see, that makes sense, especially since the input that sounds fine is specifically the UX2 "stereo monitor in". The KB has no line outs, just stereo headphone out. I think it's odd that my KB is even stereo output though, the sound coming from the left and right earphones sound the same to me. Some sound patches are mono on keyboards, some have 'enhanced' sound with reverb, etc, to give a stereo presence, and others are full-on stereo. Quote Link to comment Share on other sites More sharing options...
