HX stomp MIDI connection options
claudeu
I have a question about HX stomp MIDI connection options.
I use a wireless MIDI connection with Yamaha MDBT01 Bluetooth between HX stomp and my iPad. The iPad sends programme change commands to the stomp from the Forscore app. In addition, I want to work simultaneously on my MacBook with the HX edit, which I have connected via the other MIDI USB output. But I need this USB output to connect a Morningstar MC 6. Now my question: Can I connect the MacBook to the HX stomp in another way without using this USB output?
I can't visualize how the USB ports look (and which are hosts). A diagram would help. But ... can you use a powered USB hub in this case? Or, a MIDI 5-pin DINs on the Stomp with a cheap MIDI-to-USB cable (I've had best luck with the iConnectivity mio).
  • 2 months later...
