claudeu Posted February 4, 2021 Share Posted February 4, 2021 I have a question about HX stomp MIDI connection options. I use a wireless MIDI connection with Yamaha MDBT01 Bluetooth between HX stomp and my iPad. The iPad sends programme change commands to the stomp from the Forscore app. In addition, I want to work simultaneously on my MacBook with the HX edit, which I have connected via the other MIDI USB output. But I need this USB output to connect a Morningstar MC 6. Now my question: Can I connect the MacBook to the HX stomp in another way without using this USB output? Quote Link to comment Share on other sites More sharing options...
soundog Posted February 7, 2021 Share Posted February 7, 2021 I can't visualize how the USB ports look (and which are hosts). A diagram would help. But ... can you use a powered USB hub in this case? Or, a MIDI 5-pin DINs on the Stomp with a cheap MIDI-to-USB cable (I've had best luck with the iConnectivity mio). Quote Link to comment Share on other sites More sharing options...
claudeu Posted February 9, 2021 Author Share Posted February 9, 2021 iConnectivity mio! Thank you for your tipp! Quote Link to comment Share on other sites More sharing options...
claudeu Posted April 16, 2021 Author Share Posted April 16, 2021 The Stomp manual says: "do not use an external USB hub!" Quote Link to comment Share on other sites More sharing options...
