dwmartin6341 Posted February 27, 2021 Share Posted February 27, 2021 Hi Guys, First time posting. I understand the concept to create Path 2 from a split. I can change the output block of Path 1 to say Path 2A. My problem is trying to get the Input block for Path 2 to say 'NONE'. Is this important? The path flow seems to work, but the Path 2 input block only has the normal options to pick. I don't see a NONE option. Firmware 3.01 Helix Rack. Has the NONE block been removed in 3.01? What I really want to do is use the two paths to get more DSP availability. You know, Path 1 signal going into Path 2, but I can't seem to get it to work. What am I missing! Thanks! Quote Link to comment Share on other sites More sharing options...
phil_m Posted February 27, 2021 Share Posted February 27, 2021 Yes, the None option is still there for Path 2. From your screenshot, it doesn't actually look like that's Path 2 based on the spacing of those lines. That looks like Path 2A and 2B. There is no None option for Path 2B. In order to feed Path 2A into 2B, you have to create 2B, the move the Split block to the end of the Path 2A. You'd have to mute the output block for 2A. Check out the "Super Serial" routing description from the manual: es, the None option is still there for Path 2. From your screenshot, it doesn't actually look like that's Path 2 based on the spacing of those lines. That looks like Path 1B (None isn't an option as an input for that). Do you have a block on that path further down the line? Quote Link to comment Share on other sites More sharing options...
CraigGT Posted February 27, 2021 Share Posted February 27, 2021 There's also a Super Serial patch in the Templates setlist that will get you going. Quote Link to comment Share on other sites More sharing options...
dwmartin6341 Posted February 27, 2021 Author Share Posted February 27, 2021 You may be on to something here. If this is path 2, how do I get to (see) path 1. I cannot seem to see all the paths. Here is a screen shot of the Super Serial Template as it appears for me in HX Edit. Thank you so much for taking the time to assist! Greatly appreciated. Quote Link to comment Share on other sites More sharing options...
phil_m Posted February 27, 2021 Share Posted February 27, 2021 48 minutes ago, dwmartin6341 said: You may be on to something here. If this is path 2, how do I get to (see) path 1. I cannot seem to see all the paths. Here is a screen shot of the Super Serial Template as it appears for me in HX Edit. Thank you so much for taking the time to assist! Greatly appreciated. So the issue is that you have the True Preset Spillover functionality enabled... So you only ever see Path 1 (or Path 1A and 1B) when this is enabled. If you want to see Path 1(A&B) and 2(A&B) you need to disable this option. You can do that by going to Global Settings>Preferences>Preset Spillover and turning it Off or holding down the ACTION button while pressing the HOME button. That will give you all the paths back. 2 1 Quote Link to comment Share on other sites More sharing options...
dwmartin6341 Posted February 27, 2021 Author Share Posted February 27, 2021 YES! Thanks so much Phil! That was the issue. Quote Link to comment Share on other sites More sharing options...
CraigGT Posted February 27, 2021 Share Posted February 27, 2021 1 hour ago, phil_m said: So the issue is that you have the True Preset Spillover functionality enabled... S Good catch, I wouldn't have spotted that one. 1 Quote Link to comment Share on other sites More sharing options...
pluto5 Posted December 4, 2021 Share Posted December 4, 2021 Thank u so much for the answer. I was in the same problem! Quote Link to comment Share on other sites More sharing options...
oscaroviedo Posted March 18, 2023 Share Posted March 18, 2023 Thank you guys!!! I lost 3 hours of my life before finding this post. Quote Link to comment Share on other sites More sharing options...
