ceedjay Posted March 14, 2021 Share Posted March 14, 2021 Hi ! What is the level of the Amp out ? Line ot instrument ? I have a Harley Benton FRFR112 arriving which I will be using as a monitor on stage (and as my amp at home). It has Line inputs, will it be ok xith the amp out ? I don't want to use the main outputs because these will go direct to PA when gigging. Thanks. Jay Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 15, 2021 Share Posted March 15, 2021 According to the manual this output is “meant to send directly to the front of your guitar amp.” So it’s instrument level. However, check the manual for Global Settings -> Ins/Outs. I believe there’s a way to have the Amp Out mirror the Main Outs. Quote Link to comment Share on other sites More sharing options...
johnalt Posted March 15, 2021 Share Posted March 15, 2021 It would be better if the volume knob controlled the amp out to. Or at least have the option in the global settings Quote Link to comment Share on other sites More sharing options...
ceedjay Posted March 15, 2021 Author Share Posted March 15, 2021 Hi, Unfortunately you can't change the output level of the Amp Out. I tried a few things. But it is quite powerful anyway so it should be ok to drive this FRFR cabinet as a monitor on stage. When used as the main cabinet for small gigs, I'll just use one of the main outputs. Maybe a small DI would be a good solution. Thanks for the answers. Cheers. Jay Quote Link to comment Share on other sites More sharing options...
